KTRE 12 bolt for 3rd gen Camaro / Firebird
For sale is one KTRE 12 bolt for the third generation Camaro and Firebird.
-Nodular iron center section w/nodular iron caps
-33 spline Moser spool and axles
-Rear has ford big bearing ends and Timkin bearings
-3.73 gear ratio
-Has Moser stud girdle heavy duty cover
-Factory ws6 rear disc brakes and lines are included
-Rear is 60 inches brake hat to brake hat with 5/8 stud upgrade
-A Wolfe Racecraft Single swaybar and Spohn lower controll arm relocation brackets have been installed.
Wolfe Race Craft
- Detail
Spohn Performance, Inc.
Professionally assembled, and 100% complete and ready to run!
I have been 8.77@163 with this rear. It is a very nice peice, i am sad to have to part with it.
First $1700 takes it!
Don Barnett
dtb400@msn.com
-3.73 gear ratio
Wolfe Race Craft
- Detail
Don Barnett
dtb400@msn.com
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If a 9" will fit, I don't see why a 12 bolt can't. You can't bolt in just any 12 bolt though, since they never built a 12 bolt with the proper 'mods' for use in a 3rdgen... meaning no mounts for the coil springs, panhard bar, or torque arm. You have to either modify a GM 12 bolt, or buy an aftermarket one for a 3rdgen F-body.
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: KTRE 12 bolt for 3rd gen Camaro / Firebird
Is it shortened and made to be used with coil overs? Or is it stock length and have spring seats?
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
12, 12bolt, 2001, 3rd, aftermarket, bolt, diff, end, firebird, gen, ktre, ktre12boltforsale, ktretransmissions, rear, t56
