Rear Axle loose?
Old 05-19-2006 | 05:33 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Rear Axle loose?
Just noticed when i push my car left or right, i can feel play in the axle left to right, id say about 2 inches.. Not good im guessing?
neeed help plz DONT WANNA DRIVE IT IF IT ISNT SAFE
Old 05-19-2006 | 06:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
scary! yea, i'd go do a few checks before you go anywhere:
you mean with the car on the ground, you can push it side to side? (check your panhard rod).
jack up the rear of the car, under the pumpkin, just get the tires off the ground, grab a wheel and try to push it in/out. If that floats then check your outer wheel bearings first, then your c-clips and inner bearings.... (if your c-clips are shot, then you should be able to grab a wheel and pull it, with your axle, in which case you'll crap your pants that it wasn't while you were driving )
Old 05-19-2006 | 06:44 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
on the ground it floats, Im going to check the panhard bar in a minute, its scary lol
Old 05-19-2006 | 06:54 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
it must be the panhard, I can see it moving around when its on the ground.. Ill tighten it tomorow when im over my cuzins, Is it safe to drive it slow there for about a half hour?
Old 05-19-2006 | 07:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
don't take turns faster then your grandma would, in a milk truck, loaded full.
I'm having a hard time picturing what's going on, if it's the axle, or the suspension. tightening it won't do anything, just see if the panhard is there, in one piece. Also your rear sway bar.
Old 05-19-2006 | 07:55 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
the panhard bar isthere see, i think i know what happened when it was in my shop getting tuned and such and reg maint, i removed the lower left side of the panhard bar so i could access the pesky rear end pumpkin Housing, Or rear end cap as you could say, i think i remeber asking one of my buddys to torque it up, apprantly he didnt.. and i do remeber hearing a nut or some tool fall on the way home so i think thats the problem i know the bolts still in i havent checked if the nut and washer fell of on the other side
customblackbird
08-15-2021 11:16 PM
draco
10-04-2015 10:25 PM
E Rod
08-28-2015 06:17 AM
red90IROCls1
08-25-2015 07:56 AM
