Changed rear end gears, what transmission speedo gears to use?
Car: 1992 Camaro RS
Engine: Head Cam LS1
Transmission: T56'er
Axle/Gears: 4:10'ers
Hello,
I have a 92 Camaro with the 700r4 transmission and electronic speedometer. What I did was swap the rear-end ring and pinion for a set of 3:73 from a 2:73. Has anyone ever performed this swap and changed out the speedo gears inside the transmission tailshaft. If so what was the color of the gears or the number? Also I am running a 245/50 original sized tire. Thanks much Chris
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
700R4, 700R4 Speedometer Gears, 4L60, 700R4 Speedometer Calibrations, 700R4 !
Try this web site. It should have your answers and the price.
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
1992 Trans Am
08-08-2015 08:16 PM
273, 4l60, camaro, end, gears, rear, recalibration, speedometer, t5, tire, transmission, troubleshooting
