what is my transmission?????
1 Post
Car: 1989 Camaro RS/ 1992 Camaro z28
Engine: 383 Stroker/ ls3 e-rod
Transmission: borge warner t-56/ tremech t-56
Axle/Gears: 10 bolt, 3.55/ dayna 44(viper) 3.07
i have a 1989 camaro 305 4 speed auto trans. i dont know what it is...like a 200R4 or a 700R4 or th 400. i dont really know my transmissions if you cann't tell...lol, but plz help me on this
thanks!!!!!!!!!!!
thanks!!!!!!!!!!!
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
A TH400 would be a 3 speed auto. 400 standing for 400 HP. Mostly for heavy duty application in trucks. And probably only big block appications. It's been around since 1964.
the TH2004R (for some reason they put the R behind the 4, maybe to keep from getting the 2 mixed up) standing for 200 HP with overdrive. Would have been used for smaller rear drive engines.
The TH700R4 they changed the HP ratings. 700 divided by 2 = 350, so it's rated at 350HP. Used in most rear drive cars and trucks since around 1980.
1 Post
Originally Posted by Benm109
You have a 700R4.
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Are you smoking crack?
lmao
http://www.maliburacing.com/auto_tranny_id.htm
http://www.nastyz28.com/transid.html
http://www.novak-adapt.com/knowledge/th700r4.htm
http://www.novak-adapt.com/knowledge/th400.htm
and theres also wikipedia.com
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
The 2004r was made for light cars and the 700r4 was made to push around big chunks of steel.
700r4=350hp, my a$$!!!
They would burn up in no time behind sluggy 180hp 305's!
I'm just stating how they named/rated the GM auto trans'. That's just what that number designates. The TH350 was rated/used with/however decided by corporate, at 350 HP. when the TH700R4 came out, it replaced the TH350 by adding an overdrive. See the similarity.
It's like when "THEY" state engine HP and torque specs. Is that actually what the HP is? You can get 500 different answers and opinions on different ratings from 500 different people.
And how YOU take care of YOUR equipment is directly proportional to the life expectancy of it.
1 Post
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
its all rated on torque capacity that the tranny is prepped for. I dont remeber the TH700R4's maximum specs but its fairly strong. More than enough to hold up your 305, just stay away from stock t-5's if you go swap, a stock 305 tpi can snap one in half. Aftermarket ones are fine. Though if you look at the gear ratios on the 700r4 on the first link it seems to have a fairly wide split between first and second.
Originally Posted by forklift
so 700r4 is a four speed VS. the rest which are 3 speeds?
the 2004R is a 4 speed aswell.
T5 manual trans 5speed
T56 manual trans 6speed
Just stating how "AUTO" transmissions got there number designations.
TH350 rear wheel drive 3 speed
TH250 rear wheel drive 3 speed
TH200 rear wheel drive 3 speed
TH700R4 rear wheel drive with overdrive
TH2004R rear wheel drive with overdrive
TH125 Front wheel drive 3 speed
Th440 Front wheel drive with overdrive 220HP rating
TH400 Rear wheel drive 3 speed
If designated with "C" at the end example TH350C indicates lockup converter clutch.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Lets put this one back on track before it turn into a pizzing match.
If the pan has 16 bolts and is basically square, it is a 700r4. How good or bad any of gm transmissions are have been debated for years. Some guys pop them behind 200 hp stuff and some of us have run more power than they shoud hope to handle with no issues. Carry on.
i have a 350 i m putting in my 1991 camaro rs and i want to keep it throttle body so i could use my wiring harnes but i have a limited amout of money about 1500 so i cant afford to buy fuel injection products with all the other thigs i had to but so i will use a used one that i will probably find at a junk yard off a truck and then bore it out and get a bigger fuel pump will it work?
Received 1,721 Likes
Re: what is my transmission?????
It's a 700-R4, aka 4L60. (similar to but not the same as 4L60E, the electronically-controlled version) GM changed the name for it in about 88 or 89, but the world at large was slow to adopt the new one.
Car: 1984 z28 2006DodgeDieselMegacab4X4
Engine: Just the 305HO for now
Transmission: 770-r4
You seem you might be able to answer my question. I have an 84 z28 and my roomate just bought a 91 rs v6. We plan on putting in a sbc so any tips would be appreciated. Anyway the question is this, do you know the different types of 700r4's? we have an unknown 350 in a truck so when we get a donor car (transmission) we need to know what id tag to look for so it will match to to 350. thx
Apologies if this is not the correct method to ask you. Im new to this stuff
1992, 700r4, 91, 92, camaro, capacity, chevy, designating, hp, information, rateing, rs, t5, th700r4, torque, transmission, transmissions
