transmission cooler lines
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
does anybody know where you can get stock replacement cooler lines that go to your tranny. one of my lines nut go rounded off because of it not even moving, so because i wanted the tranny out so i can rebuild it, i just cut it so i could get it out.
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
did you try the dealer?
if not, if i remember right, you should be able to cut it cleanly, install another tube nut over the tube, and re-flare it. those lines shoudl have some play (not much) that would allow you to do that. (like i said...that's if i remember correctly. if that sounds crazy, then ignore it)
-Brian
-Brian
