anyone have the mega shifter instructions
Car: 79z28 91z28 89 irocz28
Engine: 383 350 tpi 350 carb
Transmission: th350 700r4 700r4
Axle/Gears: ford 8.8 3.73 ? 3.23
I pulled the shifter out of a car i wrecked and cant find my paper work on it ......... if anyone knows the wiring for the park /neutral switch i could use some help. thanks Damian
I cant figure out how to send it to ya ..but the wiring for the neutral switch are the purple and yellow wire to the top switch and the dark blue and light green to the reverse lights bottom switch I hope that helps you
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Stolen RS you should have just e-mailed me but lucky for you I saw this so the instructions are on the way.
