B&M Megashifter very stiff out of park......
Car: 85 IROC/First Year Of The "Roc"
Engine: 305........for now
Transmission: 700R4/Corvette Shift Kit
I had a B&M megashifter installed about 3 months ago and its very stiff when going from Park to Reverse. The guy said it would get easier over time but still it seems the same. Every thing else works fine. I have a brand new tranny and shifter cable so I know that cant be it. Any help would be greatly appreciated.............
Back when I still had my 700R4, my megashifter was stiff coming out of part for like 3 years. I adjusted the cable and shifter some, it helped a little. I got used to it and had no problem with it, I could pull it out of park like nothing. My 100lb Fiancee could barely get it out of park with both hands!
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Guys, you have to use the search feature and look through the results. If you find my name in every one of these posts you'll see I kept posting the same thing over and over. To this day I have the recommendation I mention in these posts and have no problems at all:
Code:
https://www.thirdgen.org/forums/auto-detailing-appearance/178961-b-m-shifter-results.html
Code:
https://www.thirdgen.org/forums/body-interior/102745-b-m-megashifter-replacement.html
Code:
https://www.thirdgen.org/forums/body-interior/76457-b-m-mega-shifter.html
Code:
https://www.thirdgen.org/forums/aftermarket-product-review/1474-b-m-megashifter.html
Code:
https://www.thirdgen.org/forums/aftermarket-product-review/484-b-m-megashifter-need.html
jimbo
Aftermarket Product Review
03-14-2001 05:35 AM
700r4, adjust, bm, cable, correct, iroc, mega, megashift, megashifter, megashofter, mgashifter, shifter, stiff, stiffness
