T-5 torque ratings
Car: 1989 Iroc Z
Axle/Gears: moser 28spline/Auburn posi w/ 3.73
T-5 torque ratings
How much torque can a t-5 handle before it blows apart?
Car: '88 IROC-Z medium orange metallic
The weak part of a stock setup is the clutch. I blew the disc into a hundred pieces a couple weeks ago with 215hp. I know a couple local guys with stock T5's behind mild L98's and they've lasted a few years so far but they don't race. I also have a customer with a turbo V6 4th gen that put 430hp/490tq to the wheels through a stock T5.
Car: 1989 Iroc Z
sweet thats a good enough answer for me, beside if it breaks i can just put something better in.
Car: 1989 Iroc Z
i'm really not sure were a good place to get a T5 rebuild kit is, but i have always wondered if there was a good kit that beefed these trannys up a bit so they can handle more torque.
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
The clutch has nothing to do with the tranny's weakness at all. If you have a shop and are telling customers this, then maybe you should hire someone more informed.
Stock T5 is good for around 300ft/lbs of abuse, WC-T5 supposedly 330ft-lbs. I've been running a WC-T5 behind my pretty healthy 383ci for a while and it's been flawless so far. No powershifting or they'll pop, just like any other tranny will. if you don't shock load it, they can last a while. usually the 3rd gear goes out in them cause people tend to shift the 2-3 hard. The gears strip, synchro's fall apart...
There's a company called G-force that makes kits, and also builds up T5's to handle 600+ft-lbs. I know the mustang guys use something called an "X" kit? too to beef theirs up as well, which would work fine as long as you retain our bellhousing.
no green
01-09-2016 09:22 PM
LT1Formula
10-08-2015 08:34 PM
