700r4 to t56 electrical connection
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
i'm doing a t56 swap and noticed on the old 700r4 there is an electrical connection is this connection used for the t56?
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I am assuming you are talking about the 4-pin plastick connector that plugs in above the linkage. No, this is not used for the manual trans. It is for the lock up function of the converter.
db057
08-11-2015 10:11 PM
