rear gear swap
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Just the ring and pinion, no problems since they're interchangable. If you want to use the carrier from the 95 (posi), you're going to need 28 spline axles for a third gen housing. If you wish to keep your 85 posi then just swap the gears.
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Originally Posted by 85blackberlinet
so to make it clear my 85 gears will slide right in right.
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
