TransGo Shift Kit Help ASAP! (Pics!)
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Okay, after a few pitfalls, I have come to this point, and I am officially stumped. I have tried my hardest to keep everything organized, but I have one problem with a spring missing, either that, or I am not using the correct spring.
I am at the point where I am re-installing the 2nd accumulator valve assembly, and the 4th accumulator pison assembly. I need to know what spring goes into the transmission between the 4th accumulator piston and the separator plate. When I pulled it down initially, I forgot what spring came out, but I did have one broken spring...not sure if it was in the 2nd accumulator assembly, or on top of the separator plate. That is here:
Does anyone know the type of spring that is supposed to be used here? As you can see in this picture, the spring that you are supposed to use is pretty long, and longer than the black spring that snapped:
But then, I have this WHITE spring that is unaccounted for so far:
But I think that white spring goes on the governer/servo thing here:
Is the spring I am supposed to be using different than both of these? I can't find any other springs anywhere, so far everything is accounted for, other than that original snapped black one, and that white one. I can't tell if that white one is new from the kit either, but it is not specified in the instructions or video, so I think it is original, and the instructions say that the spring in the back of the governer is original too.
Can ANYONE clear this up for me ASAP? Any help at all, no matter how small it is. I want to get this install done!
No, the "white" spring does not go there. Give me a call at 909 7951876 anytime past 12 noon PST, and I will walk you through this, ok.
Last edited by Pro Built Automatics; 04-01-2006 at 08:46 AM. Reason: Automerged Doublepost
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I would call trans-go. I know that is not what you want to hear but they would know best.
Do not take out the mtv spring trust me. and while you have it all apart put a tv valve in in they are like 30-40 bucks you will thank me later.
I do not think that trans-go gives you new accumulator springs. just springs.
you could buy a new spring or take the one from the 4th accum in the case and plug the hole by tapping a check ball in there.
I'd buy a new spring personally.
