LS1 T56 Rotation Orientation.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
For those of you that have installed the LS1 T56, is it installed traight up with the trans mount being flush to the undercarriage, or is there about a 12º Clockwise rotation of the trans?
I can mount it in both ways, and the crossmember I just borrowed is designed to have it rotated. If I rotate it, it looks like the shifter my face the passenger side just a hair sitting in neutral between 3-4 gears.
-Paul
-Paul
No one knows?
C'mon, I know I'm not the only one putting one of these in.
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
Originally Posted by Twilightoptics
No one knows?
![Stick Out Tongue](https://www.thirdgen.org/forums/images/smilies/tongue.gif)
Actually. the LS1 seems to be just as easy. Especially since it uses all the original T5 stuff including the bellhousing and hydraulics.
