th200 to th350 shifter cable
Car: 1982 z28, 2007 Silverado
Engine: 350 Chevy, 10-1 CR, Comp Cams 270h
Transmission: Th350,
Hello, I've switched my metric 200 trans out for a freshly rebuilt th-350. I used the B&M Torque arm adapter kit. Everything went fine except for the shifter cable...
The cable bracket that bolted to the pan of the 200 will not fit the 350 pan. So I went to the junkyard and got a bracket from a 350 pan out of second gen. Now the problem is the braket is too far back, and will not allow the transmission detent to move all the way forward into park.
So I ordered a B&M brakcet and detent kit, but the B&M brakcet will not fit my stock cable...
Anyone have a solution, might something from a third gen with a 700r4 work?
Thanks!
Thanks!
Well, I read how someone used their stock cable with a b&m megashifter, so the opposite should be true (should be able to use the megashifter cable with the stock shifter), and I ordered up a b&m shifter cable with an adjustable threaded end, as well as a new pan bracket and dentent bracket...
Hope it works
Hope it works
Night rider327
02-25-2016 09:50 AM
