A4 - T5 Swap Question
Car: 1986 Camaro Z28
Axle/Gears: 3.73 Posi
When the 'new' T5 is sitting under the car, the top part that the shifter bolts to is not square to the floor. Is this normal for the T5? IF this is normal, will the shifter bolted on sit normal inside the car?
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
the t-5 in a thrid gen doesn't bolt in straight up, its at a 17 degree angle. so no it shouldn't be square. the right shifter for a third gen has a bend in it to compensate so the top of it is about straight up.
