t5 from capri
Old 02-28-2006 | 09:31 AM
85blackberlinet's Avatar
Car: 85 berlinetta
Engine: none
Transmission: 700r4very soon t5
t5 from capri
stupid question i have a t5 from a 5.0 can is there a way this can work in my 85
Old 02-28-2006 | 10:21 AM
ede's Avatar
ede
it's a good question, never been ask before. no it won't work.
Old 03-03-2006 | 06:38 AM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
Yeah, fagetaboutit! (<--insert Italian accent here). The input shaft splines,input shaft length, pilot bearing dimensions, throwout bearing retainer thickness, torque arm mount, shifter mounting, and trans mount mounting are all different. I'm sure there are a host of other differences too.
Old 03-04-2006 | 10:04 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
short of changing the case. getting a disc that is for that spline. differant yoke for the drive shaft (maybe shorting the driveshaft because the input shaft is longer and you would need a spacer plate) and the piolot bearing yes I think you could pull it off. but after all that work you would have a good chance the shifter hole would be off to far since you just moved the trans back further.
DrummerDad
03-13-2008 09:26 PM
phess11
10-04-2005 07:48 AM
Camaro_1986_19
Theoretical and Street Racing
34
09-07-2002 11:58 PM
duke_mushroom
12-21-2001 12:52 AM
D.DASTURDLEE
10-27-2001 06:07 AM
Quick Reply: t5 from capri
