Will a stock 10 bolt hold up?
Car: 1984 Trans Am
Engine: just a little 305 ; )
Transmission: the original t700r4 ; )
Axle/Gears: stock 10 bolt w/4.10 or 4.56 richmond gears
I have a 1984 Trans Am w/ the original 10 bolt. It has factory limited slip and i think it has 3.08 gears.My Question is this:I want to put either 4.10 or 4.56 gears in it to,will the 10 bolt last long and isit worth buying and having these gears installed? Drivetrain is in sig.
Car: 1984 Trans Am
what do yall recommend running? 12 bolt,9",dana?
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
i have a moser spool, and axles, c-clip elimnator kit and had no probs running a 10 bolt at the strip with slicks. a 12 bolt or 9" for trird gens is going to cost 2000+ . moser everything will cost abot 500 to 600 . i got this stuff while i was running a 468 bbc with 150 nos. and never broke it so i think it will hold up with mods.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think you'd be lucky if it survived, but your call.
as I like to preach:
solid pinion spacer, axle girdle, weld tubes, main cap studs.
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I have a 10 bolt and am planning on beefing it up in the near future, both these articles are under misc. modifications in the Technical Articles section, i copyed the links for you.
http://www.ws6transam.org/10bolt.html
https://www.thirdgen.org/newdesign/t...nguprear.shtml
seems to be alot cheaper then new or even used danas
Terrell351
06-13-2021 01:13 PM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
