T-5 fluid?
Received 1,858 Likes
This question comes up ALOT.
Assuming your transmission still is what came in your car, you have the 1st design T-5; with brass blocking rings.
Ignore what GM says, and the crap that someone will probably post in response to your question, about how you need to know exactly what transmission you have because GM specifies gear lube in 83 & 84, ATF in 85, gear lube in 86, or whatever. Their recommendation changed several times over the years. They waffled back and forth between gear lube and ATF, even though the actual parts themselves ARE IDENTICAL IN EVERY WAY (and therefore their actual lube needs, whatever those are, are also the same...). It is as though they had some kind of internal war going on between warranty costs (which argue in favor of gear lube) and CAFE (which would favor ATF). The parts did not change until 88, when they went to the new design T-5, which has composition blocking rings; those need some kind of friction modifier, and so their lube spec was always ATF which at least makes sense unlike the early transmission.
Use synthetic gear lube such as Mobil 1. It takes about 2.5 quarts. The drain and fill plugs are both on the passenger side of the case; DO NOT take off the bolt looking thing on the driver's side!!!! If you do, you will be pulling the transmission out and disassembling it, to put the thing that falls apart when you do that, back together.
Car: 83Z28 HO
Transmission: G Force 5 speed
I can tell you I initially tried to use gear lube (80/90) on my '83 NWC T-5 - because my Haynes manual said so.....and it was horrible.
When cold, it was a pain to get into any gear until it warmed up, then it shifted fine. I later switched to Mobil-1 synthetic Dex III and have had no problems since. I now run a G Force T-5, (WC)and they recommended the use of Mobil-1 ATF. As a matter of fact, they insisted I use it.
- Just my experience with it.
EDIT: I never tried Mobil-1 gear lube like Sofa recommended, so maybe that'll work too. I dunno.
Car: 92 Camaro Z28
Engine: LB9
Transmission: world class T5
Axle/Gears: stock ten bolt
I used ATF fluid and it works great.
Also my dad cut up a piece of hose stuck then i fed it down the passenger side exhaust manifold to him and he stuck it in the transmission then I put a funnel on the end and started pouring....easy way to do things
Car: 85' IROC & 87' IROC conv
Engine: Both have Vortec TPI 350
Transmission: T-50
Axle/Gears: 3:42 & 3:73
I use Amsoil 10-30 oil with Slick 50 additive my trans shift excellent!
Car: 83Z28 HO
Transmission: T-50
I have tried just about every fluid available Synthetic Dexron, synthetic gear oil, different oil weights and all the regular oils with only fair results. I use Amsoil in all my vehicles so I decided to try some 10-30 and that works perfect, A friend of mine had a T-50 that was noisy so he added some PTFE additive and cured the noise so I combined the 2 lubes and now have a trans that shifts excellent even over 6K RPM.
Car: 88 GTA
what do you all think of penzoil synchromesh for gm vehicles?
i have a few friends that have used it in their 5spd cars (imports) and it has solved grinding and hard shifting problems.
Car: 88 GTA
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
so anyone ever use it...its developed specifically for gm vehicles???
Car: 88 GTA
HoosierinWA
10-07-2015 10:15 AM
