Whining noise coming from the rear end at speed
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
At about 10mph a small whining noise comes out of the axle and the faster i get , bigger is the sound . It sounds like a plane at highway speed . It's a 89 bird LO3 with 700r4 and 2.73 gear .
Is it the wheel bearings or the internal bearings?
Car: 1989 Trans Am
Engine: 305TPI
Transmission: World-Class T-5
im having the same problem out of my 89 t/a... sounds like a bad whining sound and it sounds like its coming from the rearend. mine just started the day after i did a few donuts in a parking lot so i figure i broke something but if anyone knows i'd like to know what it is. email me if you may know something tankomatic420@yahoo.com
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
My rear whined with speed - higher pitch at higher speeds - it was the pinion bearing in the rear end. Not a hard replacement - remove drive shaft from rear, move it aside (but leave it in the tranny unless you want a tranny fluid bath), and go from there.
Make sure you mark the driveshaft so you get it back right - bolting it back the same way makes a difference in balance.
Get the solid pinion spacer instead - to replace the crush sleeve (you can search here for the part number - I think they can be had from Summit).
And get a brand new pinion nut, they aren't supposed to be reused. Any parts store will have it.
Car: 1992 RS
Engine: Carbed 350
No problem - I hope that's all it is for you - it's a cheap fix and easily done in the driveway. Email me if you need anything else - I may not know, but I'll gladly try!
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Well since this thread is already opened I have a ? When I am driving I hear a soung like the rear tires are scraping on the inner fender, well but I have checked and the tires are not scraping. I have a new 10 bolt posi rear end on her could I have the same problem or is this a normal sound?
Car: 1992 RS
Engine: Carbed 350
a "scraping" sound - gears would be more of a whining sound - maybe the rear brakes - I'd check brakes first before I started tearing into the rear.
1 Post
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I sounds more like a rubbing sound than a scraping sound. Have you ever been in a car and heard the sound of the tires rubbing on the ineer fender well? It sounds exactally like that, the brakes are newly redone with new crossed drilled rotors
Car: 1992 RS
Engine: Carbed 350
OK - rubbing sound might be rear then - a very low pitched "whining" - like when your tire runs over the yellow line onto those grooves in the pavement to wake you up!
brrrrrrbrrrrrrbrrrrrrbrrrrr
I'm no expert at all ... but I know my whining rear was pinion, and it was an easy fix so I tried it myself and was successful. Does the sound change pitch with speed? You could try pinion bearing as well - it's not hard to do, and way cheaper to replace than having the rear tore into by a shop.
Is it a 4th gen rear by chance? If so, you might wanna register and post question on a 4th gen board - they would know more about the 4th gen rears - they change to zexel-torsion diff's in the 4th gen line somewhere - a whole new posi beast. The only part of a rear I'll venture into is the pinion bearing, and removal of the c-clips for wheel bearings - beyond that it's time for a pro in my book.
Car: 1989 Trans Am
Engine: 305TPI
i just took my car to the shop on wednesday and i was told it was the pinion bearing making that noise... it got worse and worse and i finally parked it. planning on rebuilding the whole car so hopefully i can just go ahead and buy a whole new rear end but just wanted to let you know that a few other people agree that that sound came from a bad pinion bearing.
hectre13
12-11-2023 08:14 AM
novaderrik
08-10-2015 12:44 PM
1992 Trans Am
08-08-2015 08:16 PM
