Need Torque specs ASAP!!!!!!!!!
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I'm dropping my engine and tranny in the car tomorrow and can't find the torque specs for a couple of things.
This is for a t56 tranny.
Flywheel to crank
pressure plate to flywheel
bellhousing to tranny case
bellhousing to block
Thanks, josh
Flywheel to crank
Thanks, josh
Car: 91 Z28 CAMARO
Engine: 305 TPI,stock
Transmission: 700R4, 2800 stall
This is from a haynes manuel.
Flywheel to crank 60ft.lbs.
pressure plate to flywheel 35 ft.lbs.
bellhousing to tranny case 45 ft.lbs.
bellhousing to block 55 ft.lbs.
If someone else has anything different or to add then great.
Hope this is going to work for ya.
no green
01-09-2016 09:22 PM
