how much fluid goes in our gm 10 bolt
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
im getting my rearend back today and i just wanted to know how much fluid it will take i plan on having it all back together and driving my car today YAY
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I just rebuilt my 9.5" 14 bolt in my truck. It took just over 2 liters. If you buy 3 quarts/liters, you should have more than enough. Posi additive if you have a posi will also be needed.
The grade of oil depends on how much you want to spend. Normally 80w90 is fine. 75w90 synthetic is better but also costs a lot more. Any multigrade that goes up to 140 is a bit of an overkill in a car.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
i've got mine on a stand building it back up. Should I turn mine so that is sits as it would in the car (pinion yoke parallel to ground, rather than pointing towards ground...), and fill up to the drain plug until it flows out? I just got a summit cover, and i'm not sure which is the fill plug...?
Car: 82 z28
Transmission: TH350
yea i got 3 quarts of 75w90 synthetic but with the additive already in it but unfortunetly i dont get my rearend back till tomarrow hopefully i can get it done before i have to drive back to chi-town for school
Hotrodboba400
12-10-2019 07:07 PM
UltRoadWarrior9
09-02-2015 08:24 PM
