CONE!...shaped, front pinion bearing??
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
ok so i went and bought the new front pinion seal and bearings..but to my surprise the dude from kragan auto parts said" the computer said there were two kinds of bearings one was cone shaped.and the other was not ..the one that is not sone shaped cost like $39 and the one that is cone shaped was only $17
Any friggin way i bought the cheaper one hoping its gonna work ,.where im at right now i wont have access to another ride to go back and exchange it for the right one??
so my question is ,.,.are the cone shaped ones the ones i need?? and why would the store computer say "Or" when it showed the difference between the two?? is it because there made by different companys or wha??
thanks for all in advance for all the feed back!!
ok so will either one work or??
when you say 9 bolt or 10 bolt..do u mean the number of bolts around the differential cover?? also whats the difference??
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The 10 bolt was the standard 7.5" or 7.625" rear available in all years, the 9 bolt was the 7.75" upgrade available in some years. Nothing is interchangeable between the two. They're easily identified by the number of bolts in the cover.
IIRC, the 10 bolt uses a tapered bearing.
ok so r u 100% sure that the ten bold uses the tapered bearing??need to know for sure,..,.,thanks
ambainb
04-25-2016 09:21 PM
lt1z350
09-29-2015 01:50 PM
