Aluminum Driveshafts
Car: 84 Z-28
Engine: 355 cu. in.
Is there anyone that would know if i could shorten and use a driveshaft out of a newer model chevy truck?(1999-current) they are aluminum and i can get a few free i think and theres a good machine shop down the road as well. My main worry is that these drivesahfts are probably twice the size around of a normal steel driveshaft. this is just a thought but if it works out good i may get a few and have them shortened and ready to go for third gen cars. so any help would be appreciated thanks
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I am not sure if the yoke will work with the f-body trans. Theoretically, you could have it cut and rebalanced and I don't see why it wouldn't fit. It wouldn't give you much room to work with though. The exhaust might have to be tweaked to give you some space.
Car: '91 TA vert
Engine: turboLSx
Be very careful with an aluminum shortened driveshaft.
I had a place that supposedly does awesome work do that to my driveline. And that was on a mostly stock 305 (hsr intake, lt1 cam). Less than a year of driving.
Make sure they'll gaurentee their work. I took this back to the place and asked them to fix it because it's obviously a failed weld and they told me to go home.
Car: 84 Z-28
Engine: 355 cu. in.
I have already talked to my machine shop and he said they have done many that were problem free so im thinkin i will be alright. but that for the advice anyway, i would definatly hate for that to happen to me as thats extremely dangerous. thanks for help though
Car: 84 Z-28
Engine: 355 cu. in.
if i had one around here i could get for that i probably would but i also have about 3 of the ones im talkin about layin around as we speak and i can get them done for about 50 bucks so i may give this a shot. also i was kinda asking cause if it works i may be able to sell them on here for say somebody that needs one for a conversion of some sort. but i will say you have a good point there
Car: 84 Z-28
Engine: 355 cu. in.
thanks i should check that then cause i didnt think about that i just assumed the u-joints would be the same i will definatly check on that
Car: transam, el camino
Engine: 415
No welders will touch an aluminum DS around here, something to do with liability? I hope you plan on running a safety loop.
Car: 84 Z-28
Engine: 355 cu. in.
Im just kinda feeling this one out for now but i trust thes guys pretty good but that is also something that need to be done for sure. yes some of the truck shafts are large like very large i have one of those but i also have a smaller one as well i think it may have came out of an s-10 maybe im not sure, because i have a s-10 myself its a zr2 and it has a humongeous aluminum shaft so im not 100 positive what they are from.
