Bad wheel or hub bearings?
With the car jacked up, I can hold the right rear wheel and pull it out and push it in 1/4-1/2 inch. This is not right. What is the problem? Is it a wheel bearing, hub bearing or what? Basically if I leave it as is, the weight of the car sitting on it, forces the rotor to ride against part of the caliper causing the outer 1/2 inch of rotor to be grinded. I can hear it grind as I drive.
Also I went to Autozone for wheel bearing and the guy asked me what rear I have, something to do with 7-1/2 or 7-3/4. The 7-3/4 was twice as expensive. The guy also said to replace either, I had to go through the rear and not behind the disc.
Please someone set me straight here.
Thanks!!
-Kevin
Thanks!!
-Kevin
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Being a 91 i would suspect its a 7.625
Count the bolts on the diff cover to be sure though.
Pull the axle and inspect the bearing.
That's what I thought he was referring to, but I thought 1989 was the last year for the 9-bolt in Fbodies. I told him 1991. Anyway, now back to my problem, what do you guys think the problem is?
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The bearing does not really control the side to side movement as much as the c-clip does. Like Ede says, there will be some movement.
ambainb
04-25-2016 09:21 PM
