Borg Warner 4 speeds
Came across a BW 4 speed out of a 3rd gen camaro (assume 82), I can get it for $100. Are these at all strong?? any specs on them like gearing?? Also I have all of the hydraulic stuff to put a t5 in my ride, will it work on this 4 speed instead??
82 were all saginaw, and were all mechanical linkage, til 83 or 84
do google on the BG 4 speed ratios, theres billions of pages with this info
good luck
good luck
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
My '82 has the stock BW super T-10 in it. Air adam has a T-10 in his as well.
Yes, these are pretty damn strong. Double check, BW had reverse in top left, saginaw had it bottom left, BW had an aluminum case, (check with magnet).
the BW mechanical linkage is a good thing, i'd rather have it over hydraulic myself.
You can check the ratios online, do a search on a BW super T-10. latest revision.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally posted by Ricktpi
All the V-8's are T-10s
this is a BW for sure. Anyone have any experience with hydraulic setup on one of these?? I was thinking I could maybe redrill my t5 BH to fit the t10 ( we used to do this on jeeps to go from t5 to t176)
Car: 1982 Trans-Am
try a search, I remember reading a thread on this a little while ago...
1 Post
Car: 82 S/E WS6
Engine: LG4 305 4BBL
Transmission: M24 B/W 4 Speed
Originally posted by Air_Adam
Not all... actually, not even most... only about 1/3 or 1/4 of the V8 cars with a 4-spd got the T-10. Most got the Saginaw box.
They were a bit stingy with the B/W in 82.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
1 Post
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
My neighbor also had a bw super t-10 behind his 1982 from factory for a reference to every1 here.
Re: Borg Warner 4 speeds
First gear is 3.42 granny gear to get the anemic 305 moving the car. Its basically like driving a U-Haul truck.
Its still probably stronger than a T5 though ....
1 Post
Car: 82 S/E WS6
Re: Re: Borg Warner 4 speeds
Unless im stopped on a steep hill I always start off in 2nd gear.
Also a U-Haul truck will never be as much fun to drive
[ON] 9 Bolt Axles Partout
6speedIROC
16
03-15-2023 08:33 PM
