1350 End Yoke for 9-Bolt Axle
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
Does spicer or any other manufacturer make a 1350 series end yoke for the borg-warner 9-bolt rear axle?
Part number?
Part number?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Probably not. Since the 9 bolt like the 7.5" 10 bolt isn't considered a high strength diff, installing a 1350 yoke would be overkill. If they do make one, it would be a special order and probably very expensive. That is if you could even find a listing for a 9 bolt anywhere.
Car: 1989 GTA
Yeah, after looking into it more, the 9 bolt would most likely fail before the 3R u-joint that it has in it now would, i will probably end up getting a strange 12 bolt, once i can afford one. Im will have my 500HP 383 SuperRam engine done by spring, so it is onnly a matter of time before the rear-end goes, oh did i mention the 150 shot on top of that.
Thanks for the reply.
rudolphschenker
09-04-2015 02:41 AM
UltRoadWarrior9
09-02-2015 08:24 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
