Is the Trans-Go 700R4 shift kit the best?
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I have previously installed the B&M shift kit and the shfits were so hard that my wife would not ride in the car because she said it hurt her back (mine too). I was wondering if the Trans-Go kit is bette, before I do my next overhaul?
Car: 1982 Z-28
WOT shifts would still be firm, and normal daily driveabilty would be dramatically improved (less harsh)?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's the idea. The Trans-Go Shift Kit doesn't really try to address shift feel at all, it just corrects some common design problems. It's the Reprogramming Kit that changes shift firmness.
To bring it back to stock first you'll probably need to replace some parts that the B&M kit changed or modified. The B&M kit just blocks the accumulators, enlarges the feed holes and jacks up the line pressure to harden the shifts.
Car: 1982 Z-28
I will be overhauling a stock 1988 IROC TH700R4. Will I need the TransGo kit plus a "reprogramming" kit?
The Trans-Go Shift Kit doesn't really try to address shift feel at all, it just corrects some common design problems. It's the Reprogramming Kit that changes shift firmness. The Shift kit does address the shift feel, just not much for WOT shifts. The Performance kit "as is" does not address the 1-2 part throttle shift very well. The Performance Shift kit that I offer offers both, smooth shifts at light throttle openings, & firm shifts at WOT. The Performance Shift kit offers better 3-2 downmshifts, the ability to hold any gear to any rpm, & keeps the 3-4 clutches from getting into trouble at anything above 5,000 rpm thru 7,800 rpm.
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I put in the trans-go shift kit and i love it. it took awhile to get it correct due to stupid mistakes that i did but after that its all good. i love it
Car: 1982 Z-28
Pro Built Automatics "The Performance Shift kit that I offer offers both, smooth shifts at light throttle openings, & firm shifts at WOT." What is your part# and price?
The cost is $ 148.32. Go to http://www.700r4l60e.com/store/custo...&cat=28&page=1 this will give you what you need.
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
dont they make an electronic shift kit now? you just plug it in, and it resets pressure or something. i think B&M makes it.
i couldve sworn i saw it on jegs the other day. but regardless, what does it do? and does it work?
Hotrodboba400
12-10-2019 07:07 PM
tonys91rs
10-10-2015 03:31 PM
TheTraut88
09-07-2015 05:22 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
