T56 sensors?
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
T56 sensors?
I am swapping a T56 into my '82.I just want to be sure that the sensors in the pic are labeled correctly.I have found old posts about which is which..but no pics.Just want visual assurance I have them identified right?
The Backup Lights arrow points to the passenger or right side of the trans as there is only one connector on that side (in the middle more or less)?
Are all years (93-02) of the T56's sensors located in the same spot?
Is there a known CAGS blockoff plug?Or can I get a simple blockoff plug from a parts store as long as the threads match?I obviously will not need it and would like to remove the sensor all together ( I am weird that way) and just put a blockoff in its place.Is there anything internal that would not allow this?
Car: Camaro
Engine: 6.2L
You've got the locations for the sensors right. Suit yourself but I'd leave that CAGS right there. If you dont wire it up it does nothing other than go along for the ride.
topteam54
10-06-2015 12:21 AM
el_muerte
09-16-2015 12:01 AM
mygta87
09-14-2015 10:36 PM
