700R4 to 4L60E -> What year?
Car: 2005 colorado 2wd, 1986 fiero GT, 1989 Firebird
Engine: None yet
Transmission: auto
I've found anything from 87 to 92. What year did GM stop putting the 700R4 in and insted used the 4L60E? Is there any easy way you can tell the diffrence b/w the two? Thanks!
Axle/Gears: '01 3.42 10 bolt
i,ve never heard of a 4l60e that was earlier than "93. the 700 has connector on the drivers side. the 4l60e has connector on the passenger side. 4l60e has no tv cable either.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
700R4 and 4l60 are the same thing, GM switched to the 4l60 name in the late 80s early 90s. a 4l60e is the electronic controlled version and was put in place in the early 90s
Edit: damn bat got to it first
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
4l60 is the same thing as 700r4.
4l60E is the trans used in all 94 and later f-body's and corvettes.
93 f-body's had teh cable operated 700r4/4l60
1 Post
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
93' - 4l60E - first year available in all rwd applications (ie. truck, passenger vehicle, except f-body) also the very last year for a 4l60/700R4.
94' - 4L60E available in all rwd applications (ie. truck, passenger, vehicle, & f-body) 4L60/700R4 no longer in production.
C409
09-01-2015 03:42 PM
Thornburg
08-25-2015 01:46 AM
