gears
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
I got Yukon Gears from Randy's Ring and Pinion and I am happy with them. They were priced pretty reasonably, run quiet, and are strong enough for street / strip use.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I believe you have 3.42 gears with an open differential.
You can go with 3.73's for a 3 series carrier and if it is in the budget get an Eaton Posi. $150-175 for the gears, $450 for the Eaton, about $100 for the bearings and install kit, $15 for the gear oil and posi additive, and around here it is about $150 to get it installed.
www.thunderracing.com
You have the 28 spline axles so the Diff is $537.
http://www.thunderracing.com/catalog...vid=6&pcid=279
http://www.thunderracing.com/catalog...&vid=6&pcid=67
Car: 86 camaro z28
Engine: 5.7 carb
what would u put in ur car.
185-19599-1 Eaton Posi Limited Slip Differential, GM 10 Bolt 7.5", 28 Spline, 3.23 and up
i like this one. this part will bolt in my rear end, without modding it.
I've got the Eaton Posi in my car with 4.10 gears and Moser Axles.
4.10's are a bit much for my 5 speed and would be a little too much for your V6 Auto.
Eaton with 3.73's would be pretty good. Bolts in with no modding.
UltRoadWarrior9
09-02-2015 08:24 PM
