speeds with 700r4/2.73's
Old 08-23-2005 | 04:56 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
i was needing to get some MPH:RPM number. my speedo needle was detatched, and not put on right. i have 89 305tbi auto. i thought i had the 700r4 with 2.73 gears. but when i plugged the numbers into the calculator on TGO, the numbers were way off. and i seriously doubt the rear gears were changed before i bought her.
according to the calculator, with 215/60 15 tires, at 1250RPM in 4th i would be going 98. i know at that speed im taching around over 2K.
are the 700r4's gear ratios:
1st - 3.06
2nd - 1.62
3rd - 1.00
4th - 0.70
any idea whats wrong here???
Old 08-23-2005 | 11:54 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
I just ran the numbers and at 70 you would be taching 1,787 rpm. You would be at around 50 at 1250 rpm. here is the link if you want to do it yourself. http://www.jawsgear.net/store/catalo...4d50aa65853011
Old 08-24-2005 | 12:06 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: speeds with 700r4/2.73's
You used tire diameter instead of radius.
Old 08-24-2005 | 06:52 AM
Car: 89 camaro rs
Engine: 305 tbi
Re: Re: speeds with 700r4/2.73's
thanks. i just went back and saw radius.
Old 08-03-2023 | 06:13 AM
81malibuwagon's Avatar
OP - which color combination did you have with the 700r4 and 2.73?
I'm going from a 700r4 w 3.23 to 2.73s I need to go the opposite way
Elephantismo
02-13-2019 12:51 AM
jrdturbo
03-31-2016 02:58 PM
$750 L98
11-07-2015 02:26 PM
RedLeader289
09-23-2015 06:50 AM
FLAP
Camaros Wanted
09-02-2015 09:22 AM
Quick Reply: speeds with 700r4/2.73's
