How to change differential fluid?
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Sorry for the stupid question, I just have never done it and would like to give it a shot while I change my tranny fluid as well. How hard is it to do?
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
There should be a filler plug on the side of the diff housing somewhere. OK make sure you've got a new gasket for the diff cover as well.
Unbolt the diff cover let it all come out. Fit new gasket, fill up the required amount via a tube into the filler plug hole et voila!
Mark.
Mark.
Car: 1987 TA
Engine: 350 stock/twecked
do not do it this way, sorry man
If you refill as much as possible the pumpkin will be entirly submerged. Also if you take the cover off you can inspect the gears. The spec book will tell you how many quarts to use. I always use mobli synthetic for gear lub. I also do not use the gasket just orage sylicone, the gasket always leaks on me maybe I am not the best, but it always works.
later and
gb
rick
iv never done it on my ta but you probably only need to take out the plug and suck it out. then refill as much as possible
later and
gb
rick
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 1987 TA
ok, but the fill hole on mine is on top, probly a different axel trhan what is supose to be under the car
you do it how ever you want
it is your car as for me I will open up the differental and inspect it also, that practice saved me from exploding a rearend before as I cracked a ring gear,
just my way
later
and
GB
rick
just my way
later
and
GB
rick
Engine: 383 Carb
Transmission: 4L60
On the 10 bolt it's on the passenger side of the housing in front of the axle. On the 9 bolt and Dana 44 it's on the cover.
1 Post
Car: 86 T/A
Engine: HSR 355
Originally posted by gimydaloot
thats how i was tought in school 8-). just ask the guys at napa or where ever u buy the gear oil
maroe624
04-16-2017 08:29 AM
EduardoRonaldo7
09-08-2015 01:28 PM
Thornburg
08-25-2015 01:46 AM
92camaroJoe
08-13-2015 06:07 AM
