700r4 to th400
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
700r4 to th400
I am looking for an answer to help out my freind, his 700r4 is shot and has a th400 for free laying around, what all will it take to make the swap? crossmember for sure but will he have to do anything else? thanks
Colt
Colt
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
tranny is longer too, gotta cut the driveshaft...
too bad it's not a th350, you could buy a torque arm adapter and slap it right in.
I have never heard of a 400 installed in a 3rd gen, just 350's.
Your best bet is to grab a 700 from a junk yard for a few hundred bucks
Car: '82 Z28
Never heard of one in a 3rd gen? A few people run them including me. I was able to use my stock driveshaft with a TH400 slip yoke put on. Only thing is, my car originally had the 3 speed 200c. The length of the TH400 short tail and TH200c are within a half inch of each other. I bought a Spohn crossmember and torque arm for the swap but I'm sure there are other options out there.
Car: 1988 Camaro
I have a th-400 in my 88 camaro.
Your buddy will need at the min.
A 82-83 F body 200c 3 speed auto driveshaft, or his stock one cut down.
A "swap kit" I used the hurst kit on mine. It has the crossmember, torque arm mount bracket, shift cable bracket, vac line, etc.. Around $115-125 from summit.
A conversion front U joint. The th-400 slip yoke is bigger and takes a bigger U joint.. The conversion Joint will have 2 caps to fit the driveshaft, and the other 2 caps will fit the slip yoke.
Th-400 slip yoke
th-350/400 torque converter
Th-400 slip yoke
darwinprice
17
10-11-2015 11:51 PM
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
