Flywheel Alignment Dowel Pin
Old 07-27-2005 | 04:08 PM
terrynot's Avatar
I am putting a 350 from a 79 Pickup in my 86 Camaro, and installing a manual T5 in as well, and I have a question. The mounting flange on the crank has a hole for an alignment dowel pin, but no pin. The flywheel has the matching hole, but no pin. Should I get a pin and install it, or not worry about it? If I need to install it, does that have to be pressed in? Unfortunately, the engine is already completly built! Where do I find a pin?
Thanks.
Terry
Old 07-28-2005 | 06:09 AM
ede's Avatar
ede
there is no dowell pin on 2 piece rear seal engines, or in other words the flywheel isn't indexed.
Ed1LE
09-30-2018 10:14 AM
Cam-aro
Camaros Wanted
11-12-2015 04:35 PM
meeklay812
10-01-2015 04:46 PM
mfp189
09-27-2015 10:25 AM
monte87cortez
09-26-2015 09:10 PM
