..found aluminum chunks
Old 07-27-2005 | 09:32 AM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
I installed a B&M kickdown valve in the 700r4 in my Camaro yesterday and found 2 pieces of aluminum about a 1/2 inch long in the pan,they are both the same shape and look kind of like teeth.The trans was rebuilt in 99' and doesn't have 30,000 km. on it since.How concerned should i be since the trans works perfectly like it always did,shifts well,TC locks up,no weird noises.The only mods have been a corvette servo and now the kickdown kit.I do shift it manually with the mega-shifter now and then.The only other thing i can think of is i remember when i picked up the car after the tranny was done ,the mechanic didn't hook up the tv cable and the car shifted VERY violently until i got it hooked back up.I only drove it once like that.From the look of the teeth,something tells me this might have done it.Those chunks have probably been there for 6 years.Opinions please.
Old 07-27-2005 | 11:47 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If they're aluminum, they won't be teeth.
Old 07-27-2005 | 07:34 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Any idea what they could be,maybe something spit out of the converter?
Old 07-27-2005 | 07:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The only thing I can think of would be some piece of the case?
Old 07-27-2005 | 11:12 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Re: ..found aluminum chunks
Since if works OK, just keep the fluid changed at recommended intervals and drive the sucka.
Linson
09-25-2021 08:55 PM
Royal_Z
09-30-2015 09:45 PM
