Gear Ratio ?
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
Gear Ratio ?
Hi guys, i was gonan ask, does anyone know what numbers i look for on my parts list, to find out my axle gear ratio. im trying to put posi in and just making sure i get the right posi. thx guys
1 Post
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Do not know what your part list is or what gear you want to run . If you are talking about a fatory build sheet I cant help you ,never had a new car . But the #'s on the front of the axle housing do not realy help . The only real way of knowing is to pull the rearend cover and look on the ring gear its self .
Engine: V8 350 ci
well someone told me to look for a number like gu3 or something i just forgot the number and i dunno where my subject went or id go look. anyway, inm trying to find out like if its 28 spline 7.5 ratio or not
1 Post
Car: 85 IROC Ht
Engine: 383 carb
ok i got' ch I belive in a 89 car you have 28 spline axle's but I do not know if that's a 9 bolt or a 10 bolt in that year . I just read a post too that said that the 9 & 10 bolt rear's have the same amount of bolt's in the cover . I would still pull the cover to find out what exactly what you need . The 10 bolt is a 7.5 if you are going to use a stock type posi it should slap right in there just remember whitch shim gose on the right & on the left . I you are geting a aftermarket one get a master rebuild kit too . You will need all that stuff . no more one wheel peal
Engine: V8 350 ci
its 10 bolt....lets just say it is 7.5, 28 spline. ok im goign to get a used one. off ebay. now if i was going to do this, what will i have to keep in mind. and also how will i know which spilne gos on the left and on the right, in meaning how do i make sure i line it up correctly. thx
1 more thing....
you think it is 26 or 28 spline?
1 more thing....
1 Post
Car: 85 IROC Ht
Engine: 383 carb
You have to pull the axles to count the splines and keep the left on the left and the right on the right . They shouuld be the same size though . I you want to mesure them put a tape on the outside of the axle (The round part with the wheel stud's) and pull on a angle to the end of the inside . The carrier will go in with the ring gear on the left .The ring gear will have the size and the gear ratio stampet on the side.
Hotrodboba400
12-10-2019 07:07 PM
dbrochard
09-19-2015 08:13 PM
83 Crossfire TA
09-08-2015 12:06 PM
UltRoadWarrior9
09-02-2015 08:24 PM
