700r4, what all did it come in
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
would a transmission outtve an 80s model S10 with a 2.8 swap into a thirdgen camaro?
1 Post
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
V6 S10 should bolt up to a V6 Camaro shouldn't it?
Use a tailshaft from a f-body 700 on the S10 700 and it should be all that needs to be done.
i dont really know if it would work but to me it sounds like it would...im actually gonna be going the oposite, i have an extra fbod transmission sittin around and the tranny in my parents s10 went south so was gonna swap them for a bday present if it would work
1 Post
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Axle/Gears: 3.27, I think
Since you are putting the f-body tranny in the S10, you just have to trade the tailhousing off the old S10 and put it on the F-body one. If it is a 2.5 4 cyl. or a 2.8 V6 two wheel drive, it can use a 700R4 from a F-body's 2.5, strongly don't use that one, 2.8 V6, or 3.1 V6. Which are all 60 degrees.
If the S10 was a 4.3 V6, you would have to use one from a V8 F-body because they are 90 degrees.
If still confused, look at the bellhousing. Does it have the same bolt pattern? If it does, then use it.
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
