Turbo 350 vs 700R4
Old 07-07-2005 | 01:40 AM
outlawracer's Avatar
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
Turbo 350 vs 700R4
i wanted to know the difference between the turbo 350 and the 700r4, in the last post i did i asked what kinda trans should i put in and i'm thing about the 700r4. the thing is that the car is going to have about 430hp, i will be taking it to the race track once a week, i will be doing alot of dailly driving. the rear end is a ford 9"with a 4.11 gear, and the motor is a 383 sb. i need something that can do all that and still have a good top speed (140/150mph), a little lumberjack told me that i mite need a overdrive to do the 140/150 thing. any info you have will help, thanks guys,
ps, and keep in mind i'm trying to run high 11s in the 1/4 mile
Old 07-07-2005 | 02:03 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
On a TH350 with 4.11 gears and a 26" tire, you'll be at about 7435 RPM at 140 mph. With a 700R4 in O/D you'll be at 5205 RPM.
Old 07-07-2005 | 12:39 PM
Engine: 87 LG4 305
but what are the difference between the turbo 350 and the 700r4,
Old 07-07-2005 | 03:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A 700R4 is a four speed overdrive with a locking torque converter clutch. The TH350 is a three speed without a locking clutch (unless it's a TH350C, which has a locking clutch).
Old 07-07-2005 | 09:43 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
With that kind of HP, the 700R4 won't last near as long as the TH350 will .... unless you replace all the internals of the 700R4 with the best parts you can get (Kevlar clutches, etc)
Old 07-07-2005 | 10:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The TH350 also has a better gear ratio. The 700R4 has a very wide 1-2 gear spread. You really need to over-rev first gear to be at a good rpm when shifting into second. It's designed to give a good low first gear when non performance gears are in the diff. 2.77 etc.
Where do you plan on doing 140/150 on an extended basis? You're not going to getting that fast in the 1/4 mile. For highway driving you don't want such a deep gear.
You might want to consider the 200-4R tranny. Better gear ratio like the TH350 but also has an overdrive like the 700R4.
Old 07-08-2005 | 01:03 AM
Engine: 87 LG4 305
thanks man, yah i dont think i'll be going 140mph for long, i just need something that can be "fast" in the 1/4 mile and still be able to be a dially driver. i would like an overdrive but thats only to same gas.
BumpaD82
Members Firebirds
31
04-04-2019 11:36 AM
camaro11j
09-19-2018 09:49 AM
camaro71633
09-01-2015 11:24 AM
Eric-86sc
08-24-2015 10:01 PM
crazynights
08-21-2015 07:53 AM
