Just spent the rent money
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Ok I just got a killer deal from Rand's ring & pinion . On the way is Eaton 28 spline posi , axle's , 373 ring and pinion & all the nessesary install part's . My ? is should I run the stock cover or is there a strength issue hear more mod's to come , also please give me an opion on an aluminum yoke . I am in there now and want to know if it's worth changing.
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Run a TA Performance girdle cover with preload bolts or similar. This will improve housing strength and keep the caps from walking around.
Aluminum yoke? Not on your life. Maybe on a full on lightweight race car, but for a typical 3rd gen I'd stay stock. If the seal surface is trashed a new yoke is about $90. Worth it to keep a puddle from forming on the floor, or in the driveway.
Car: 85 IROC Ht
Engine: 383 carb
Thanx TKO I will serch the cover you mentiond I am trying to get this allrite as I move in the foward direction on the car sus and tranny next motor last . Can I find this cover in JEG'S , PAW , ECT .Once agian thank you very much
Yeah, I'm sure you can get the covers in JEGS, Summit, etc. Just amke sure that they have the preload bolts, and it isn't just an aluminum dress up cover.
No problem. Post back or PM me anytime.
Bohemian
Aftermarket Product Review
11-25-2015 09:38 PM
bigjay89gta
10-15-2015 08:04 AM
HoosierinWA
10-07-2015 10:15 AM
