What's the difference between TH350 and TH350C?
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I have a buddy with a TH350C in a van and I have a TH350 in my drag racer. I'd like to only get one rebuild manual if these trannies are almost the same.
Does anyone know how they differ? I know the TH350C has lockup, but what else is different? Just the valve bodies or are the rotating assemblies different too? Thanks.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Just the valve body. Oh, and the input that feeds the lockup.
Re: What's the difference between TH350 and TH350C?
Car: 92 Camaro
I just got done completely rebuilding the 350C.
The main thing I could tell is that there is an auxillary valve body with the lockup solenoid stuck to it on the TH350C. Also I saw in the Chilton manual that there is an additional check ball if you have lockup. I didn't rebuild the pump, but that probably had some lockup specific instructions as well.
Clutch clearances, bolt torques, and endplays seemed to be the same for both models.
