Alum. Driveline
Car: 1991 RS
Engine: 305 TBI
Transmission: AUTO
Alum. Driveline
I am thinking about putting an aluminum driveline out of an 1LE man. transmission car into my normal V8 automatic vehicle..Will this driveline fit?? Should I feel much if any difference??
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Alum. Driveline
1 Post
Car: 1991 Chevy Camaro
Engine: 305 TBI
Originally posted by Cadillac
How do you find these? I want one!
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Many thirdgens other than the 1LE cars came with an aluminum driveshaft. Look for a JG1 RPO. My '91 GTA came with one from the factory (until the tard who owned it before me towed the thing and let the driveshaft drag on the ground.. grr).. I'd recommend an LS1 aluminum shaft (what I'm running now), they have the vibration dampner and run smoooooth...
Car: 1991 RS
Engine: 305 TBI
Transmission: AUTO
I've got a couple feelers out for the 3rd Gen driveshaft but would really like that LS1 shaft you mention. Sounds peachy (and expensive). Am I right?
Car: 1995 Corvette
The going rate for an LS1 shaft in good shape is ~$150... Thats what I paid for mine, and it was well worth it after dealing with a vibration-plagued old steel shaft..
Where do I go for an LS1 shaft? I'm asking as a lazy man. You all know this.
OK. I found and can purchase a 1LE aluminum shaft for 165 which includes shipping (and CA state tax). Is this shaft as good as the LS1 shaft?
Anyone?
Originally posted by RBob
LS1 driveshaft, aluminum w/damper: #12564004, GM dealer $263.11US.
RBob.
RBob.
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
I just called the chevy parts dealer in my area for the price
of 12564004 driveshaft they want 411.00 dollars
plus tax.
Im in NYC.
plus tax.
Im in NYC.
Car: 89 Firebird
Engine: 383 stroker 11 to 1
Transmission: th350
Axle/Gears: 3.73 posi
I just found a couple on ebay, looks like you could get them for around $150.00. Buy 2 and send me one for Xmas!
Yep.
I want to be sure though. Will all of these fit the Third Gen?
Ebay Search for LS1 Drivesshaft
Curious.
Curious.
Car: 1987 Black IROC-Z (SOLD)
Lot of aluminum 1le dr shafts out there. Look for RPO JG1 and the P/N for the 2 3/4 dia is 10085375. About $100/150 on E-bay or about $240 new from GMpartsdirect with both yokes.
Is the RPO or the P/N supposed to be printed on the yoke itself somewhere?
Unless someone peeled it off the p/n should be on the shaft. at least it was on mine when I bought it.
Car: 86 Camaro Z28
I checked with gmpartsdirect.com
They want 50 dollars shipping.
I thought it only wieghed 10lbs.
Car: 86 IROC
Engine: 5.0
Transmission: 5 speed
how much of a difference
any of you that have put a LS1 aluminum in your camaros please post results of the difference it made to your cars.
Thinking of buying one but i want to make sure it is worth it first. What are the benefits of having one?
Thanks for your replys you rock........
(awsome thread for info)
p.s have a rasping noise below the shifter when over 80 km/h. not too much vibration. Have been told its probably the shaft/universals. Anyone relate to this noise? Have also heard that the stock shafts are garbage and are problem plagued. Is there any truth to this?
Thanks again
Thanks again
The only advantages of a Aluminum Dr Shaft (1LE/LS1) are less weigth in the rotating mass, ;ess vibration at high speeds and a very small HP increase from it. Otherwise you will NOT notice much of a difference.
Note: I have a 1LE shaft on my car that I paid $110 for and if you have to pay more then $150 for one forget it.
Search around. The 1LE shafts are far more plentiful than people imagine. A couple of years ago, after hearing how rare they were, I started a search and found one within 20 minutes--long short short I eventually found and sold around 70 (yes, 70) of them. Check out the on-line salvage yards. I bought from all over the US and Canada.
JamesC
JamesC
Car: 1995 Corvette
Isn't this "1LE" shaft the same as the JG1 option Aluminum driveshaft that came as factory equipment on a lot of late thirdgens??
Car: 90' Trans Am
Engine: 94' LT1
Transmission: Built 700R4
sorry to hijack this but Ive got a question too...
Im in the process of putting a new 700R4 in my 90' w/ LT1 swap in...
Just took down the driveshaft and it is aluminum.....there is no option code on this car that states aluminum drive shaft??...
were there any other besides 1LE and JG1???
Mine is a WS6 5.7L w/auto
when the engine was transplanted I guess the builder could have put it in then too?...
