vss for th350 in 91 z?
Car: 89 rs
Engine: 355
Transmission: th350
Axle/Gears: 4.56 posi
our '91 z has the electric 140 speedo in it, and a th350 trans. does anyone know what speed sensor to use? also, what color is the buffer box on these cars?
Car: too many ...
As far as I know all TH350's use a cable speedo, not VSS. You would either have to use a conversion box (converts cable speedo to VSS speedo) or replace the stock 91 guage cluster with new guages (and a cable speedo). I would go for the first option. I've seen people into the SBC Jaguar swap use cable to VSS converters, might want to start your search there ...
TMZIrocZ350
10-07-2015 12:09 PM
