How hard is it to install a ratcheting shifter?
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I've done all sorts of body work and general maintanence but have never worked on a transmission. I'd LOVE to get a ratcheting shifter but I'm not sure if I'm comfortable installing it. How hard and how long does it take the average guy to install?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
No modifications needed. It's a bolt in item.
Well maybe the only modification might be to drill some different mounting holes depending on what shifter you buy.
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
yeah dude its fairly easy (so far its been at least, lol)
i dont have a rachet shifter, rather a gated shifter, but basicly a shifters a shifter and the only difference would be in the shifter mechanism itself, but pretty much ya just gotta bolt it to the tranny tunnel and then install and run the cable the way the directions say to and i guess you'll be fine....
i've still gotta put my engine and tranny in, but i bolted the shifter in yesterday
only thing i had to do was i used some bolts and washers as a sort of spacer between the actual tranny tunnel and the little brackets that are there for the shifter, cause it was just pulling the brackets down when i was tightening the bolts and stuff
but yeah, it shouldnt be a problem
in the first pic ya can see sorta how it bolts down, in the second pic its how its gonna stay (gotta get a new carpet eventually so it doesnt look quite so bad and unfinished)
Car: 2002 Formula Firebird
Transmission: 4l60e
B&M megashifters are pretty easy to install. The hardest part is getting the cable adjusted right. It will take you about 2 hours maybe to install it and maybe 30 min to 1 hour to get the cable perfect. It isn't to bad. I love the megashifter to.
Car: 1986 Firebird
Engine: 2.8 V6
A lot of people rush thru the shift cable adjustment... not sure why.
If you get the B&M Console Megashifter- and probably any other console ratchet- here's a tip. First read thru the instructions; if one of the steps needs a part, seal the part into a baggie and write the step # on the baggie. That way when you do the installation "for real", you're not shuffling thru parts on the garage floor- you'll have them all labeled out and ready to grab.
Car: 1986 Firebird
Engine: 2.8 V6
Here's a link with more info, and near the bottom, you'll see my picture (with the steering wheel off, I was fixing my ignition lock) https://www.thirdgen.org/techbb2/sho...hreadid=172801
ambainb
04-25-2016 09:21 PM
NBrehm
08-25-2015 11:49 PM
