10 Bolt Capacity/Fluid
i have a 10 bolt with an eaton posi and 3.73 gears...got a few questions
How much does a 10 bolt rearend hold?
Which fluid should i go with? i was thinking royal purple, anybody know of something better?
which weight should I get?
Then to fill it you just un screw that bolt near the top that looks like you just stick a half inch drive in there and unbolt it right? on the passenger side..
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Re: 10 Bolt Capacity/Fluid
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Eaton says not to use synthetic with their carrier. So does Auburn. Which means I won't use either of their products.
alright i put 2 pints in plus the additive....is it full?....because my dad said as far as he knows, its supposed to be full up to the bottom of that hole...and he can't feel anything with his finger....is it full? i have a stock cover too...
Car: 92' B4C Camaro
Transmission: G-Force T5
I just rebuilt my 10 bolt, it took just under 2 bottles of gear lube plus the additive.
I used the Long cylinder type bottles. I don't have a bottle in front of me right to see if it is 1 pint per bottle.
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
just a FYI....I have a 3rd gen and a 4th gen..the 85 will hold just 2 quarts and additive with an aurburn, The fouth gen (aurburn equipped) will hold 2.25-2.5 plus additive, the case on the fourth gen is different in the "floor" of the pig which adds that extra, the fourth gen one looks alot thinner too.
running 85w- 140 valvoline in the 85 and 75w-90 redline in the 97SS
UltRoadWarrior9
09-02-2015 09:24 PM
