T 5 Pilot bushing slap worn out why?
Old 03-16-2005 | 01:05 AM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I blew a clutch at an open track day. Pulled the clutch out and went to install the new unit and the alignment tool was very loose.
Checked the piolt bushing and it was oversized enough to stick the big end of a 3/8 socket extension inside of it. It would swallow a 5/8 bolt.
I even used the extension to pack the grease to back out the bushing.
I put it back together with new bushing as I needed to get the car moving. I did not have time to do a post mordum.
Why would the bushing wear this much and was this what destroyed the clutch?
I do not want any more transmission removal experience ant time soon. It is not fun on your back putting a T 5 back in.
Old 03-16-2005 | 01:11 AM
rjmcgee's Avatar
This doesn't help you now, but for about $15 at Summit you can get a bearing instead of the bushing. Just put one in mine this weekend.
hectre13
Car Audio
26
03-03-2022 06:38 PM
Ed1LE
09-30-2018 10:14 AM
FormulasOnly
07-23-2018 09:47 AM
92projectcamaro
09-29-2015 08:07 PM
mfp189
09-27-2015 10:25 AM
