what tranny fluid to use?
just went and picked up my high performance 700r4. it will recieve an ATI converter with roughly a 2800-3000 stall converter. it has all new rebesto clutches and bands, hardend sun shell, transgo shift kit, and some other goodies that i can't remember off the top of my head. what transmission fluid would you recommend? the tranny is supposed to hold 400hp without issues. it will see all of my 330hp on a regular basis.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Probably any brand of Dexron fluid would do just fine, as long as you actually change it and the filter once in a while.
i change my fluids on a regular basis.
what do you think about those Auto Parts Store brand fluids? i have been using it in my stock tranny, and haven't seen a lot of issues, but with they high stall and the shift kit, i didn't know if there was a preferred brand.
Engine: 383 Carb
Transmission: 4L60
Store brand fluid is still made by the same manufacturers as the other stuff, just with a different label on the bottle. Use any brand you want, just don't let it overheat.
1 Post
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Originally posted by mw66nova
right on. is the factory cooler in the rad. gonna be sufficient or do i need to pick up a stand alone tranny cooler?
Engine: 383 Carb
Transmission: 4L60
As long as your TCC works the stock cooler would be fine in most cases, but as mentioned an auxiliary cooler would be a good idea.
Engine: 383 Carb
Transmission: 4L60
Originally posted by V8 Slayer
Trick Shift or Mobil 1 Tranny Fluid?
Don't by that B&M Trick Shift garbage. It's plain old Ford Type-F fluid with blue dye in it.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
HoosierinWA
10-07-2015 10:15 AM
