700R4 to T5 speedo swap
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
I'm swapping a T5 from an 84 TA with 3.73's into my 85 ta with 3.23's. My new 350 makes plenty of torque to make the 3.23's fun, but also sucks enough gas to warrent the lower gears. My question is if I can simply swap the speedometer drive and driven gears from my 700R4 to the T5 and vice versa (I'll be selling the other car as an automatic).
-Corrupted
-Corrupted
Car: `86 SS / `87 SS
No. The drive & driven gears are different. So is the driven gear sleeve and o-ring seal.
The speedo cable will hook right up though.
Car: '85 TA
oh, good. now I get to break out the trusty calculator and figure out what color sprockets I'm gonna need. What was the equation? (gear ratio) x (paint color) / (original gear color) + (# of previous owners) = my age. Right? No, I've seen the articles, I'm just to lazy to read them until I actually need them.
So are these part numbers for T5 or a 700R4? I found them in the Tech Articles on the homepage.
Part No. Teeth Color Sleeve*
25513042 35 Orange 25007338
25513043 36 White 25007338
25513044 37 Red 25007338
25513045 38 Blue 25007338
25513046 39 Brown 25007338
25513047 40 Black 25007339
25513048 41 Yellow 25007339
25513049 42 Green 25007339
25513050 43 Purple 25007339
25513051 44 Dk Gray 25007339
25513052 45 Lt Blue 25007339
Thanks!
-Corrupted
Thanks!
-Corrupted
