WC T-5 fluid capacity
Old 03-02-2005, 09:35 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Anybody know the answer to this quick question?
Scott
Old 03-02-2005, 09:38 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
3.5QTS. for a wc. takes DM2 or above fluid
I had to look it up last week when I installed mine.
Old 03-02-2005, 11:59 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Thanks!
BTW, did you fill it from the shifter or did you use the fill hole on the side?
My mechanic used the fill hole and it only took two quarts.
Thanks again,
Scott
Old 03-02-2005, 12:02 PM
Dale's Avatar
Engine: 350 S-TPI
I filled from the shifter area. But I took the fill plug out the side and poured. I belive it took around 3'ish to fill to that hole though.
Also, it may have never drained ALL the fluid out when it was pulled. I think the 3.5 is from a fresh rebuild or install.
Old 03-02-2005, 11:48 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I just rebuilt my WC T-5 and it takes exatly 3 quarts to be up to the fill plug. You can pour it in either through the shifter or the side plug.
Old 03-03-2005, 05:38 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
2.95 quarts. Wether its a fresh rebuild or not.
HoosierinWA
10-07-2015 10:15 AM
meeklay812
10-01-2015 03:46 PM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
mfp189
09-27-2015 09:25 AM
DARKmj16
09-09-2015 04:07 PM
Quick Reply: WC T-5 fluid capacity
