i dont know what wrong
Car: 92 camaro rs
Transmission: 5 speed
i have a 92 camaro with a v8 and 5 speed and at around 65mph i get a shaking feeling coming from the pass, rear side i think its somthing in the rear end its a open rear end any thought would help. i also tried a tire rotation.
thanks. jason
thanks. jason
Car: 4
Engine: 6
Transmission: 5
Swap the tires from left to right and see if the problem moves with the tire. If it does, then you've got a bent wheel, or a triangular tire. If it doesn't, you probably have a bent axle, from curbing it.
