Thm 700 R4
Car: '90 Camaro RS
Engine: 191 V6
Transmission: THM 700 R4
Thm 700 R4
Noticed there are alot of issues with these trannies. But My camaro is on it's third one ( as far as I know) and this one is out of an S-10. I have had problems with it requiring a lot of rpms to accel and shift, almost like a slip. I have asked mechanics and freinds about this, and the mechs say to play with the throttle cable. I have done this, but it only seems to make matters worse. I have had freinds tell me the same thing and also that it may be the tourqe converter, or a clogged filter. The filter I haven't had the time to check, and the torque converter I am clueless about. Let's face it, I am rather clueless altogether about my car, but I want to fix that. Anyway, I need help and would appreciate any and all ideas that could save me some time and money on the matter. Right now I only have $400 to work with, and working on it myself is pretty much out. (No time and no place to work on it anymore.) Thanks in advance!
1 Post
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Yeah i would remove and replace the filter , thats really cheap and easy so start with that . A clogged filter can cause a lot of things to happen.
Car: 1991 Z28
Transmission: 700r4 for now
If you don't know what your doing and you mess with the detent cable or otherwise called the TV cable you can burn up a 700R4 within 5 miles. That cable changes the pressure in your trans. I have just gone through the same thing. Hope it's helpfull.
Car: '90 Camaro RS
Engine: 191 V6
thank you very much im taking it in on monday to get the fluid/filter changed. need to find some one that will let me work on it in there garage since i can't here and dont want to fork out the doughh to have someone else do it. but thanks for the warning on the cable, i wasn't aware of that. I really dont want to have to buy another tranny.
ty!
ty!
84 TA NV
09-06-2015 08:02 PM
