drive shaft help for th400
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
just built a 350 with a th400. installed it in a 86 camaro with 305. 700r, lots of fun. im looking for a cost effective drive shaft. original is 3" to short. th400 has bolt on yoke. looks like i need a shaft 44.5 ". are there any cars out there i can scavage one from or should i get a longer one and have it shortened. also will i have any problems with a yoke to yoke bolt up. thanks any ideas will be appriciated.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Almost certainly nothing stock you could use. With a bolt-on yoke you'll need to get a custom a 2 piece driveshaft made, or you'll need to change it to a slip yoke to use a 1 piece shaft.
Engine: 4++,350 & 305 CIs
Un bolt your yoke on the 400 and use a stock slip type yoke or you will have a bind problem
Car: 86 CAMARO
thanks was leaning towards a 2 piece from a 4 wd truck and having it cut to length and ballanced. seems like the most cost effective way.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You won't find any cars with a 2 piece driveshaft nor will you find anything other than a third gen that's the proper length. If you try to have a truck 2 piece driveshaft cut down to length then rebalanced, it would be better to just have a new one made.
Find or buy a TH400 slip yoke and use a third gen driveshaft that's close to the proper length. Better yet, have a custom driveshaft built that either uses 1330 or 1350 series u-joints. You should also use the same series yokes on the tranny and diff but adaptor u-joints are available.
Factory driveshafts are not as strong as they could be. Get one made from 3" x .083 steel with yokes for whatever series u-joint you want to use.
Car: 1988 Camaro
I done the th-400 swap in mine. I used a short shaft th-400 and slip yoke from a 74 vette.
The vette yokes are diff than most. It's still a slip yoke, but where the U joints fit is more like the rear end pinion yoke, than a norm slip yoke. It has U joint straps, and 4 bolts.
As far as a driveshaft. I used one from an 82 or 83 camaro that had the th-200 (or was it th-250) auto 3 speed trans. It was the right lenght for mine
I did have to get a bastard joint for the front though. The driveshaft had smaller U joints plus held in with plastic (reinstall with inside clips) and the slip yoke had bigger joints and needed the outside type clip. I found the right U joint for this at auto zone in thier brute force solid body line for around $20
I would get a Th400 slip yoke driveshaft and have it retubed with 1 length of new tubing to be the proper length just like Stephen said. Can't go wrong with Spicer 1350 joints.
Car: 87 IROC L98
Slide the slip yoke all the way into the tranny. Pull it back out 1". Measure from the center of the u-joint on the slip yoke to the center of the u-joint on the diff yoke. That's the proper length driveshaft you need.
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Car: 86 CAMARO
thanks for all the info.just started motor after 4 months of building . man what a rush, especially with open headers. the only thing left is drive shaft ! need a little more clarification on 400 yoke. mine has a center bolt but when i pulled it off it looked any other slip yoke. can any body edubicate me ? i think i will go with custom made shaft once i get length with conversion u joint up front.( th400 is a rebuilt 1973 from 1 ton truck.)
We had on in the shop and used a 200R4 length driveshaft with a normal turbo 400 slip yoke ... is it a short tailshaft trans????
Car: 86 CAMARO
tony, yes it is a short shaft 400. would you know what year car i should look for for that drive shaft ? my shaft from 86 305 w/ 700 was about 3" short. could you explain the difference in yokes on the 400s or any links im still a little confused.
Car: 86 CAMARO
im going nuts ! im looking at part web sites and there slip yokes look exactly like what i have but they have a plate welded on the u joint end where i have a bolt hole ? whats the darn difference ?
Get a yoke from something like a 70 Chevelle with a t400 ..
what you have is for a 4wheel drive 2 piece driveshaft
Call a trans shop or a 4 wheel drive and they will help you out .. i think the yoke is around 80 bucks.. you might need a different U joint also
Car: 86 CAMARO
thanks tony. your correct had 2 piece drive shaft. going to hit junk yard this weekend and look for slip yoke and drive shaft. i have a good shop here that can mod up the correct size. low on funds and did not want to have a custom one made from scratch.
Car: 87 IROC L98
The majority of the trucks that had TH400's also had 2 driveshafts. That's why the yoke is bolted to the output shaft. The front driveshaft was solid and held up by a center bearing. The rear driveshaft was a 2 piece.
This is what you want but it's only for a 1310 series u-joint which is all you're going to find in the junkyard anyway. Spend a little more and get everything in 1350 series.
http://store.summitracing.com/defaul...8&autoview=sku
1992rs/ss
16
01-28-2016 09:58 PM
Ozz1967
08-16-2015 10:23 PM
